I have a 1946 Chevrolet 2 Ton truck that I have just taken the transmission apart on. It has some pitting on the gears and some of the bearing need to be replaced. Does anybody have any ideas as to what other transmission would bolt up to the 235 six cylinder that sits in this ole truck? I believe that the current transmission is a 5 speed T-33 Warner. Or do you know of any body that would be able to get me parts for the tranny. At what point do I replace the gears. Tranny seems to run good in all gears except for 5th where it whines a little bit when running in that gear.
Thanks for any help
Joe
Joe Z
