| | | Forums66 Topics128,077 Posts1,055,928 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#79916 07/12/2007 11:09 PM | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | if you have a old points dist layin around why not take it apart and just use the shaft in a drill motor. not that the screwdriver is a bad idea. i think you can get better pressure with the speed on a drill motor and like stated you can even check the pressure. i like to make it a family affair and have my wife work the drill motor (which she hates to do) while i turn the engine. she is always so tired of hearing about the engine at that point that she will help to get it out of here. i also prime it again but with out turning after it is installed, right before i estimate timing and fire it up. good luck, firing up a new one is such a thrill. hr | | |
