7 members (ShopRag, Tstan7, Hanks custodian, Bill Hanlon, MickeyP, HandyAndy, Hotrod Lincoln),
74
Mod | | | Forums66 Topics128,022 Posts1,055,352 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2011 Posts: 141 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 141 | The starter was changed. And it has the 12 volt neg ground.
There is a small red jumper wire that goes from the big red wire/bolt on alt to the plastic connector with the second yellow wire next to it. The yellow wire is no connected now. The lights are not powered yet also. As is the gas gage.
I was wondering if the yellow wire from the alt goes to the panel somewhere? He had run it through the fire wall but not connected it. There was a plan the install turn signals, but I'm going to wait and do that as a separate project.
Trombones Totem Poles And Old Trucks!
