7 members (KEVINSKI, ronsway, Otto Skorzeny, Greg_H, 1955 1 Series, TrknGMC, TooMany2count),
157
3
Mod | | | Forums66 Topics128,142 Posts1,056,481 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,819 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,819 | Most people would jump at the chance to have a 292, and make a boat anchor out of their 230. Unless you're trying for a concours restoration to win car shows with, stick with the bigger engine. 230's were also notorious for getting cracks in the block between the valve lifter bores, which sometime let coolant leak into the oil. The motor mounts would have to be modified to install a 292, as the 230's and 250's had the front mounts directly across from each other, and the passenger's side mount is offset toward the front on a 292. Jerry
