You might check which head it has on it. There was a higher compression head made for the 235 which you will like. The casting number was 3836848, I believe.
It was used as the replacement head for the 6 cylinder Corvette engine among other stock 235 uses. It was also the head of choice for folks building a 261 racing motor.
Kurt
