| | | Forums66 Topics128,092 Posts1,056,451 Members48,443 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#79263 06/27/2007 3:24 AM | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | i think the difference is the two inner bearings have different od's. the inner holes in the block are smaller. the id's are all the same on the bearings. this is in the older ones at some point they started to use all the same size. i have installed both i think the bigger ones or outside ones can be driven into the inner ones but it can cause cam binding. i think there is .010" difference of something. the cam should be same but you have to get bearings for the block. i think there are only the two variations for those engines. good luck and hope i haven't steered you wrong. hr | | |
