| | | Forums66 Topics128,077 Posts1,055,932 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#79061 06/23/2007 11:30 AM | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | I agree it would have to be a very massive internal leak to cause that low of pressure on start up. Or could the pickup tube for the pump be partially clogged or too close to the pan bottom?
If bearing clearances were too great, looks like something would be making noise. Does this engine have an external oil cooler? If not, look at the adapter for the spin on oil filter and make sure the relief valve and spring are still in place.
Check the main bearings to see if perhaps a bearing half might be missing. It still looks to me like it would make noise without one shell in place, but it might not. But with one shell missing it wouldn't pressure up very well.
Good luck in your hunting and let us know what you find. | | |
