Originally posted by Bilbo:
I'd like to hear how to tell, from the outside, whether I have babbitt bearings or inserts?
Insert bearings require higher oil pressure to work right. Measure your oil pressure. If you have something like 15 psi, I would say that you have babbit. If you have 35-40 or more psi, I would say you have inserts.
