| | | Forums66 Topics128,030 Posts1,055,418 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2000 Posts: 248 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 248 | Guy dropped off ...free...a complete Chev 6... bellhousing to fan...carb to starter/gen. Claims it is a 235..
It has the look of a 216... two acorn nuts on ribbed valve cover..... under the carb. it has the external oil distribution cover of the 216..... on the dizzy side the lifter cover is short... doesn't cover all the way to the plugs...oil pan has raised pad on dizzy side.... too filthy to see if it has a stamped number...
Block number on pad behind the dizzy says..
Y 24340
Casting numbers will need to be scratched clean to read....
Is it an early...53 splash/babbit 235...?
Hey the price was right...
Thanks fellas.
Bob C.
Bob C. CMP Heaven The Hammond Barn
