| | | Forums66 Topics128,141 Posts1,056,487 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Not that big of a problem Drew. Although I haven't had the occasion to do one my self I have a friend that used the reproduced fenders on his ‘50 show truck, it had a seam at the front and they welded it and filled it and you couldn't tell it was ever there. I don't recall what the seam looked like because they had the work done before I saw it. I'm sure that it wasn't just overlapped without using an offset flange to make the two surfaces flush. The other way they could be is simply to have 90° flanges turned in at the edge and then spot weld them. Either way it wouldn't be a problem to make it disappear. DG
Denny G Sandwich, IL
