| | | Forums66 Topics128,134 Posts1,056,410 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,815 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,815 | Another approach is a 377. That's a 400 small block bored .030", with a 350 crankshaft. It's got better RPM capability than the long stroke 383, and with 6" connecting rods installed, it gets pretty close to the ideal 2:1 rod:stroke ratio that maximizes the thrust on the piston in the upper half of the piston travel. I built several dirt track engines on that setup and won a lot of races with them. Jerry
