7 members (55shaker, Jeff Ogden, RoadsScholar, Gray_Ghost, Ponchogl, fonz8261, 1 invisible),
82
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,131 Posts1,056,722 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#78773 06/14/2007 4:47 PM | Joined: Jul 2006 Posts: 707 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 707 | But the chances are that replacing the fitting will do the trick. Gentle heat, as Ghostrider says, will be enough, and only to loosen old dirty grease. A low mpact repair is always best for an old machine, if it works. Grease fittings are cheap. 1951 3800 Be the change you want to see. -hotshoe
