| | | Forums66 Topics128,066 Posts1,055,871 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy doug one, although it is never actually spelled out in any instruction I've read, I believe the intent was to set the timing without any vacuum or centrifugal advance. The instruction for static timing (not running) the engine says to make sure the vacuum advance is in its full retard position. The instruction for for timing a running engine with a timing light says to keep the engine at idling speed so that the centrifugal advance does not come into play. So I would say that disconnecting and plugging the vacuum advance while timing the engine with a timing light would not cause any problems. I hope that helps. | | |
