| | | Forums66 Topics128,030 Posts1,055,418 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | If the voltage is there, polarity is correct, and socket housing is truly grounded, then I'd look for a contact problem. Is the aftermarket (I assume) socket too deep? How about socket is too large in diameter for the plug in. Try this, Take the cigar lighter from your working other car and try it in the suspect socket. Does it work?
