| | | Forums66 Topics128,195 Posts1,057,378 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | Get a shop manual , You line up the dot on the cam gear with the dot on the crank gear ,the crank gear dot is at a tooth and the dot on the cam gear is in between two teeth,if you're putting in engine together get a shop manual for that year truck and engine all the places like Clasic of America have them as reprints and they will help alot as you're building the engine and the truck.When building it's good just to leave it on the bench so it's handy.
Pete | | |
