Its the damndest thing, I usually park the truck so the passenger side is up against the building in the shade. But I had to just run in this morning and when I came out I saw the difference.
I'll measure it and see if the springs are in the same direction. I'd believe that, considering the rest of the work done on this thing in the past.
is the center bolt a special beast?
I'm off to drop the axle and poke around...
back soon.
thanks for the help!
Jeremy
