3 members (68ironhead, 49nut, 1 invisible),
49
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,691 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#78344 06/03/2007 2:38 PM | Joined: Mar 2005 Posts: 684 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 684 | If it has the correct spring it should return to idle. Make sure the accelerator rod is not binding and the bell crank is free and lubed. Also check that the pedal hinge it self with the rod disconnected is not dry and binding. And if the there is excess wear in the linkage it should probaly be replaced or repaired. | | |
