1 members (Hotrod Lincoln),
327
3
Mod | | | Forums66 Topics128,169 Posts1,057,102 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2006 Posts: 693 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 693 | there is an internal tube for this oiling (you can see it if you pull the lifter cover) which often clogs. in the past a kit to re-route the oil tube externally was offered and this is likely what you have. my '56 235 has the same set-up. tom | | |
