OK. My fronts are parking/turn signals, no problem. But I want to keep the tail lights I have now but want tail light, brake light and turn signals like a modern vehicle. How can I do this without adding another pair of lights in the back? I'm finding this confusing because before the frame off, I had this set up working, no problem. Only difference was I had the fender mounted signals in the front. The back tail lights had 2 housings identical to the current set up.
Thanks for your help.
