I found 1960 and up diagrams say two wires from motor. One to ignition switched pos and one to wiper switch. A third wire may be for washer or 2 speed? One diagram says white to wiper switch and pink to ign switched pos. Do the wires have these colors? I think the picture from squeeze shows a yel and a blk. But they may not be pigtail leads just assy interconnects. Someone who has a 58/59 shop manual may post the info. Good luck.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn |
