I'm installing a new generic wiring harness on my '50 3100. Everything except the brake lights are working. Rear harness has a wire for tail lights and for left & right turn signals. Turn signals are wired to a Signal-Stat setup. Turn signals and tail lights work fine. Tail lights are 2 bulb type from Classic:
http://www.classicparts.com/1947-53-Taillamp-Assembly-Painted-R-Bluedot/productinfo/49-026/ . Wire comes from taillights to terminal on headlight switch. Have 1 wire from fuse panel going the brake switch (batt +) Have a wire from stop switch to brake switch (ignition wire).
I know I’m missing something but what?
