| | | Forums66 Topics128,134 Posts1,056,406 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,815 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,815 | The line is a 1-piece setup from the oil distributor near the exhaust pipe to the valve lifter area on the opposite side of the block. It goes through the water jacket on the way, so it must be sealed. The fittings in the block the line goes through have compression-type ferrules that are one-time use items. If you want to replace the line, most of the antique parts distributors have a kit available that includes a line the right size and the necessary fittings to do the job. You only get one chance to do it right. Jerry
