| | | Forums66 Topics128,050 Posts1,055,643 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2010 Posts: 91 Shop Shark | | Shop Shark Joined: Oct 2010 Posts: 91 | hello DR my truck has a early 261 engine with a (high)water pump.the block has two round water passage holes.if you go to Patricks website it is on the links section.he has a section on the high and low waterpump issue.i believe he sells a plate to convert to high mount pump.i just replaced my pump and got it at NAPA for about $40.00 good luck Andy | | |
