| | | Forums66 Topics128,043 Posts1,055,609 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2004 Posts: 143 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 143 | I am having some problems with the shift linkage on my ’50 3100. I went back thru and adjusted the linkage, box and shifter. Now for the next 2 problems:
1. The shift rod is hitting the clutch fork and will not allow it to shift into gear. The clutch pedal is adjusted correctly for free play but there is not enough clearance for the shift rod. Do I just need to bend the shift rod to give me the clearance or is there something else I need to do?
2. I dropped a ’56 235 in place of the 216 and the shift rod is brushing the manifold. I’ve carefully ground a bit off the linkage & manifold but would feel better with more clearance. What have others done when encountering this problem?
Thanks.
It never costs more to ask and it never costs more to think big.
