| | | Forums66 Topics128,035 Posts1,055,567 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,760 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,760 | Be sure to run a "glaze breaker" hone or a button hone in the cylinders to break up the slick surface so the new rings can seat, and then scrub the cylinders vigorously with HOT soapy water and a stiff-bristle brush to get the hone grit out of them. Follow up with a rinse with the hottest water you can get to remove the soap. I use a strong Tide solution and an old round toilet brush, followed by a rinse with a garden hose connected to the drain fitting on my water heater. Don't worry about getting the crankcase wet, but do tie some throwaway rags around the connecting rod journals on the crankshaft or wrap them in duct tape to keep grit away from them during the honing process. When the cylinder is clean, it will flash-rust as soon as the hot water evaporates, so oil it slightly as soon as the rust begins to appear. No rust- - - -not clean enough! Jerry
