Hi Folks,
When I got my truck it was a basket case and although re painted it wasn't put back together correctly. The passenger door opens and closes as it should but the driver's side is a disaster. You have to slam it to get it to close and then the trailing edge sticks out at least a 1/2". The front edge is about 1/8 to 1/4" behind the fender edge. Have adjusted the striker plate as best I can but there must be more adjustment somewhere. When I start off in first gear the door chatters in the striker plate - but only just a bit. It is somewhat annoying. The hinges and pins are tight - no play that I can see or feel.
Thanks for any tips or tricks!
