1 members (Hotrod Lincoln),
49
6
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#77621 05/16/2007 12:25 AM | Joined: Mar 2007 Posts: 3,372 Crusty Old Sarge | | Crusty Old Sarge Joined: Mar 2007 Posts: 3,372 | I'm with Builder it sounds like it may have gotten wet. If the engine set up for awhile with the exhaust valve open it may have come in through there. I would see if the engine rolls over and check the other cylinders. You could pull the push rods out to close the valves and add compressed air to the cylinders, remove the thermostat housing and watch for air bubbles. If you see any it show a bad head gasket, if not than you may get lucky.
~ Craig 1958 Viking 4400"The Book of Thor"Read the story in the DITY1960 Chevrolet C10"A Family Heirloom"Follow the story in the DITY Gallery'59 Apache 31, 327 V8 (0.030 over), Muncie M20 4 Speed, GM 10 Bolt Rear... long term project (30 years and counting) If you don't like driving yourTruck, you won't drive yourTruck..| Living life in the SLOW lane | | |
