I think there was a previous post about two relays in parallel, not two breakers. You should check the current draw of the fan. If it is excessive then maybe your fan motor has a problem. There are 30 amp little breakers that you can get. Also if you think it is an initial draw problem, look for a special fuse for motor loads. They will takle more on startup.
