From all the research I've done, there ain't a 110v compressor that's worth a [censored]. If I want good CFM, 220v Is where it's at. It's for home use. I'd really like to get a blast cabinet one day. any suggestions on what to get and where to get it?
Determining the capacity of compressor one needs has been discussed extensively in the past. The short version is you need to look at the requirements of the largest "air hog" tool you'll be using and buy a compressor that has that minimum rating. For example if your blast cabinet requires 14CFM @ 90PSI you'll need to look at compressors with that as a
minimum rating continuous output.
