| | | Forums66 Topics128,021 Posts1,055,372 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy stevebolt, yes I would reverse the connections you made to the "tail" terminal, and the "park" terminal. The turn signals are not involved with the light switch. The unmarked terminal may be for the dash light circuit, you could check it with a meter to see when it has power/conductivity from the "batt" terminal, hope that helps. | | |
