7 members (Nick in Manitou, Pre '68 Dave, cmayna, carbking, greenie-reddy, Oswald, 66flea),
362
2
Mod | | | Forums66 Topics128,160 Posts1,057,050 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2010 Posts: 97 'Bolter | | 'Bolter Joined: Dec 2010 Posts: 97 | Have you taken your sample stud to a truck suspension and brake shop? Not a dealer but an independant specialist in these areas with a parts department run by an older guy who can work a catalog as well as a computer and likes a challenge to help a guy. In Ottawa I try Malmberg equipment for this but they are only in this area. When I was looking for dowel washers (cone shaped, used to locate axle shaft to hub studs) they pulled out the Euclid (part of ArvinMeritor) catalog and that catalog had over 20 pages of wheel studs. Have a look at http://xpresswaypluscatalog.arvinmeritor.com/Good luck. | | |
