I meant shoes...sorry, its the Back passanger side, I took off the axle shaft,and there was a metal gasket between the axle shaft and hub,it seemed to have that rubber instant gasket seal on it...there was oil running out at this time. I jacked it up a bit more so the oil would stop running out.I tightend the adjusting nut lock,and I am going to put some gasket seal on the metal gasket before I put the shaft back in. I have a grease gun..should I load it with universal grease at this time? M/G
