| | | Forums66 Topics128,142 Posts1,056,485 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#76766 04/25/2007 3:56 AM | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | The slot is just to identify it as special.
From 1938-62, only two head bolt part numbers are listed for 216, 235 and 261. Long and short except for a special drilled bolt, used when a 59-62 block is used with earlier top end* to reduce the oil flow to the rockers.
Note in parts book: Use with drilled bolt. Plug # 3764579 Install in block oil port near right center head bolt. (This plug blocks the original oil path and sends it through the drilled head bolt)
· The cylinder head did not change but the rockers did.
See the USA in your vintage Chevrolet! My Blog | | |
