Bill, what kind of modifications did you have to make to get the trans to work? The one that I have has no shift arms (I was thinking of using the arms on my standard 3-spd) but it has the wiring harness on it. What did you do for the o/d shift cable, were there any modifications to the shift linkages, and how did you wire it up? I would like to get a toggle switch with a light in it from my FLAPS and mount it on the dash under my heater control knob. Would that work?
