2 members (Guitplayer, MickeyP),
70
2
Mod | | | Forums66 Topics128,021 Posts1,055,356 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,746 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,746 | Got any part numbers available? I can't imagine a reason for that much price difference, particularly for the same charging capacity. There is a heavy-duty double contact regulator, but it was designed for use with the 50-55 amp Oldsmobile and Cadillac generators with ball bearings on both ends. As long as the current regulator can control the generator at 30 amps, I'd pick the lower-priced regulator for my own use. You can replace it three times for the cost of the pricey one. Regulators just aren't that complicated! Is there a different warranty, maybe? Jerry
