7 members (RoadsScholar, Hanks custodian, thekid1950, Peggy M, Hotrod Lincoln, dt235sd, Thomaslb),
193
2
Mod | | | Forums66 Topics128,080 Posts1,056,063 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#76584 04/24/2007 4:03 PM | Joined: Apr 2005 Posts: 2,098 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,098 | 57, You will probably find as many opinions as there are replacement kits out there. You can make the stock brakes perform OK with new parts. It all depends on the intended use. After rebuilding and/or replacing everything on the stock system I still did not have the confidence to compete with the maniacs on the So Cal freeways. Ultimately I upgraded to a 5 lug front disc brake system with a dual diaphram booster, dual master cylinder & proportioning valve (mounted under the truck). I don't hesitate to drive it anywhere. Fred
1956 3100 Pickup/Red/350/3sp OD/PS/Disc Brakes 1957 Bel Air Sport Coupe/Red/355/TH350/PS/Disc Brakes 2017 Silverado LT Single Cab SB/Black/5.3/6 Speed Trans 1947 Willys CJ2A w/F-Head engine
