| | | Forums66 Topics128,168 Posts1,057,098 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2010 Posts: 170 'Bolter | | 'Bolter Joined: Jun 2010 Posts: 170 | I looked in the tech tips for discs but don't see any ideas for removing existing front hubs from the drums. For those of you who used your stock hubs with discs - how did you remove the hubs from the drums? The splines on the hub bolts seem to be pressed in extremly tightly. Did you drill out the bolts? Thanks.
PS. Tried the shop manual but it makes no mention of removing or mounting hubs & drums. | | | |
Entire Thread
37-46 existing hubs for disc brakes
| Daves46pu | 07/25/2011 11:10 PM | |
