8 members (greenie-reddy, Wayne67vert, 2-Ton, Otto Skorzeny, Gray_Ghost, Greg_H, papas52, WICruiser),
144
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,152 Posts1,056,825 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | welcome to the shop Jimmy - I've never heard of a 2 speed front for a 4x4, and keep in mind that the front and rear differential ratios need to be nearly identical to work .... the only way I'd think you could do it would be to find a 1T or larger 4x and swap the whole drive line in - early 4x conversions were done on big trucks for the military [scarce and more likely 6x6] or you might find a newer 4x to work with - OTOH, a 2T 4x won't be much use except for climbing walls  Bill | | |
