| | | Forums66 Topics128,074 Posts1,055,999 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2005 Posts: 946 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 946 | Jerry, That would explain it. I had to release the lever to pull cable out, so that makes sense. So simple! Thanks.
Dave, Take a look at these instructional plates for my NAPCO. The left reproduction sticker shows how the transfer case needs to be in neutral for Power Take Off (my winch comes off the t-case). Ignore the plate in the middle, it is incorrect to my truck. The original plate on the bottom, states to operate winch in first, second or reverse gears of tranny. The plate in the upper right is an original tire pressure plate.
Entire Thread
PTO Winch question, How do i work it
| Perro | 07/14/2011 3:00 AM |
Re: PTO Winch question, How do i work it
| Cletis | 07/14/2011 3:07 AM |
| Perro | 07/14/2011 3:30 AM |
| healingbear | 07/14/2011 4:00 AM |
| Hotrod Lincoln | 07/14/2011 5:01 AM |
| jomichael | 07/14/2011 2:28 PM |
| alkay3 | 07/19/2011 5:27 PM |
| jomichael | 07/21/2011 9:26 PM |
| alkay3 | 07/22/2011 4:50 PM |
| jomichael | 07/22/2011 6:02 PM |
| Hotrod Lincoln | 07/23/2011 12:59 AM |
| 53moneypit | 07/23/2011 8:12 PM |
| jomichael | 07/24/2011 6:59 PM | |
