7 members (Gdads51, TUTS 59, WICruiser, Phak1, Wheelie, Bill Hanlon, 1955 1 Series),
101
3
Mod | | | Forums66 Topics128,187 Posts1,057,325 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | If you have a 34 master or truck you will need: 1938-46 truck bellhousing to mate to the 235 engine and 34 master/truck transmission. You will also need a front bearing retainer from a 1938-46 truck 4 speed. It has a sleeve for the needed ball bearing throw-out bearing. It is not so easy if you have a Standard.
See the USA in your vintage Chevrolet! My Blog | | |
