The 58 which followed me home recently has one major problem which is the fact it has no wheels. This is due to the fact there have been no axles to mount any wheels on.
Well half of this problem has been solved with the purchase of some used springs from a local bolter, the purchse of new mounting hardware, the purchase of a 10 bolt rear axle from a 1970 Camaro from the local Craigslist, a trailer axle mounting kit I had on the shelf, and new 2" spring perches.
The results are shown on the attached link.
It is obvious to me the frame will need a C notch mode. Is this how others have lowered their task force trucks? If not did you use different shackles or an aftermarket spring kit?
http://www.picturetrail.com/gallery/view?p=999&gid=8309838&uid=2902753
