2 members (3800rao, Rich'sToys),
119
6
Mod | | | Forums66 Topics128,186 Posts1,057,211 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2007 Posts: 328 'Bolter | | 'Bolter Joined: Jul 2007 Posts: 328 | An electric fan set up will be fine for you as long as you ascertain the right size fan... (bigger is better, usually) and determine whether it's gonna be a "pusher" or a "puller".
I run mine on a fan relay and a switch in the cab. Failures of the thermostatic controls and probes I've had over the years causes me to avoid them. But, I'm sure you'll move enough air on your application. I've found that I don't even need the fan(s) on at highway speeds. I've run these set ups on 350's in tight quarters on early Ford hot rods, and on my small and big block Buicks with no problems.
My current 51 panel has the 455 Buick with a 16 inch electric fan mounted on the front of the Radiator on a Painless fan relay kit. Been hot here lately and it works fine
mike
