| | | Forums66 Topics128,204 Posts1,057,298 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,879 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,879 | The parts don't swap, particularly the armature. The shaft diameter is different. It sounds like you've either got a battery that's going south, a starter that needs rebuilding, or an engine in need of a tune-up. There's no excuse for hard starting if the fuel and ignition systems are functioning propoerly, hot or cold. The engine should start in a maximum of 5 to 10 turns of the crankshaft, maybe 2-3 seconds of cranking. Jerry
