| | | Forums66 Topics128,004 Posts1,055,246 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2008 Posts: 319 Shop Shark | | Shop Shark Joined: Dec 2008 Posts: 319 | While the distributor is driven by the cam, the ignition timing is set to the crank position, and controlled by the ECU. I think there's a "procedure" for setting the initial timing at or near TDC, and then letting the ECU do it's thing, but I'm not familiar with the specifics. I don't think 135k is so many miles that you have to worry...yet. If it had "jumped a link" your valve timing would be off, but this is highly unlikely. Your ECU may be the culprit.
cm If you can't fix it with a hammer and screwdriver, you need a bigger hammer.1965 Chevy C10 | | |
