I don't have a 3/4 Ton but here is what I see from the manual. Fig 79 on page 4-52 shows the driveline from the ball back past the center hanger, open universal and slip joint. Your torque tube extends back from the ball and ends inside the center hanger assembly. There is a seal in there and if it leaks, it will leak out of the center hanger area.
1951 1 Ton Completed
