| | | Forums66 Topics128,274 Posts1,058,431 Members48,489 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#76159 04/10/2007 5:55 PM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Just judging from the rocker cover, I'd say it's a '58-'62. All of the '55-'57 235/261 engines I've seen have the filler at the front of the cover, the '58 and later seem to be all to the center. Looks like the radiator has been changed, too. The upper hose should be lined up straight with the neck on the engine, not at an angle. In addition to the # by the distributor, there's also a casting date above the starter that will narrow things down as well. For the rear gears, you'll have 5.13s. That's the only gear ratio that was used on those trucks, unless the center section was changed to a 3/4 ton, then it's most likely a 4.56. It should have a 4 speed, but there was a somewhat rare option of a heavy duty 3 speed in the 1 ton.
Bill Burmeister | | | |
Entire Thread
WHAT IS THIS THING 261, 235, 216?
| Lost1953 | 04/10/2007 4:00 PM |
Re: WHAT IS THIS THING 261, 235, 216?
| waldo53 | 04/10/2007 4:22 PM |
| LONGBOX55 | 04/10/2007 5:55 PM |
| Lost1953 | 04/10/2007 6:16 PM |
| Wada | 04/10/2007 6:29 PM |
| Lost1953 | 04/10/2007 6:49 PM |
| LONGBOX55 | 04/10/2007 7:57 PM |
| LONGBOX55 | 04/10/2007 10:59 PM |
| 4ontheFloor | 04/11/2007 12:33 AM |
| Lost1953 | 04/11/2007 9:20 PM |
| Darin367 | 04/11/2007 9:46 PM |
| 58apache_man | 04/11/2007 10:12 PM |
| Brendan M | 04/12/2007 12:50 AM |
| Brendan M | 04/14/2007 3:08 AM |
| Lost1953 | 04/26/2007 2:59 AM |
| Brendan M | 04/26/2007 4:40 AM |
| starkweatherr | 04/26/2007 1:52 PM |
| Chester | 04/26/2007 3:57 PM |
| Lost1953 | 04/26/2007 11:38 PM |
| Lost1953 | 04/26/2007 11:52 PM | |
