1 members (Forty9),
96
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,072 Posts1,055,903 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | The sender must match the gauge. If the truth be known, the sender is a variable resistor and the gauge an ohmmeter of sorts. You can research past posts on testing the sender with hot water with a real ohmmeter. Get different values of resistance for different water temps. Then you plug those resistance values into your gauge. You now know your sysyem works and what those little marks on your temp gauge really mean temperture wise. This of course assumes that the wiring and such is correct and working. BTW, and yes to the electronic techie guys, I know an ohmmeter is really an ampmeter.
