| | | Forums66 Topics128,043 Posts1,055,614 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2005 Posts: 388 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 388 | The block was probably purchased from Chevrolet as a replacement block or engine as no serial number is stamped into the distributor pad. The block has the correct casting number and date code (I 174 => September 17, 1954?) consistent for a 54-55 261. Does it hace the correct bore (3.750" or greater) and the high water pump mount?
Hoyt | | |
