Originally Posted by Village_Idiot
Squeeze:
if I use the violet as the bypass it should got to the "R" terminal of the new solenoid and the green will still go to the + side of the coil and I can pick up a switched power source for the new button to the "S" terminal of the solenoid.
yes, with the push switch as 3B outlines
