| Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,792 | You have a late-model harmonic balancer with the TDC mark close to the 12:00 position. You'll either need to change timing covers, or re-mark the balancer for the conventional timing scale position between 2:00 and 3:00 that was used up until the 1980's or so. It's not that difficult to re-mark the balancer ring accurately once the true TDC is located. Jerry
